I have the wire crimpers as described. After cutting the 10 x 24 stainless steel screw ( which was tuff ) , I put the freshly cut screw end against the grinder wheel to dress up the end a little. The pliers are well used. The die nut is approxitmatly 30 years old but rarely used. frustrated mostly. It should be automatic and simple. A new screw will not spin into this die. Why haven't I seen this before?
Mike H
