Thread: Junk Motor
Old 01-12-2007, 11:36 AM
cbreez cbreez is offline
That's not a likely scenario in that little time...are they next to one another? Make sure the leakage is from the rings, not the valves. With a lean condition, you still should have lubrication on the cylinder walls. Did you have a good leakdown test first, then it went bad?
good luck...
