Old 01-14-2007, 06:33 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Are the heads leaking oil or water? is your oil black or frothy brown looking? have you checked? do you notice oil traces from the bottom of the head down the block? or is it leaking from the bottom of the valve cover gaskets down the head?
If it is any leaking other than from the valve cover gaskets you may try re-torqing the heads (sometimes works,usually doesn't work). Then you are faced with pulling the top-end off, replace the head gaskets ,manifold and exhausts and put it all back together again.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
