Low, medium, and high rise has to do with how tall the intake manifold is and the intake should be matched to the heads. (low to low, med to med, and high to high). This will give you the best performance. Hood clearance can be a problem with medium and high rise heads/intake. Lower usually more torque, higher usually more hp at rpm. The medium rise heads you have are great for the street. Other options you are asking about largely depend on what you plan on doing with the car. What type of driving and so on. Hope this helps some, Jim
