Rod Bearings?
Hi All,
I just removed one piston to check what rod bearings I have. They are Clevite CB760PE (12 88). It has been quite some time, although very few miles, since the motor had been rebuilt and I do not have the spec sheet. I thought the crank had been ground which I would assume about .010. I tried measuring the crank journal which appeared to be 2.432. When I went online to check the Clevite PN their was no indication the bearing is +/- .010 or so. I will recheck my crank journal measaurment.
The back of the bearing does not indicate any type of +/- size. Just the Clevite PN. If the bearing was different from stock wouldn't be indicated either on the back of the bearing or on the Summit website?
BTW this is a 65/66-427 S/O. C5AE-6300-C=Crank
Thanks,
Mike
Rubber peelin' gears a jammin'!
