Old 01-16-2007, 10:40 AM
hkelley's Avatar
hkelley hkelley is offline
Cobra Make, Engine: SPF #2101 Diamond Ed.; 460
Default Looking for Comments on 460 Build and Components
I recently purchased a Superformance with the following engine build. I am looking for info/comments/input as to what is good or bad in this particular build. Thanks in advance.
Joe
460 Cobra Jet Bracket Race SVO
10.5:1 Compression ratio
Edelbrock Performer 460 intake manifold w/Holley 750 CFM
SVO Cobra Jet aluminum heads with SVO valve train M-6049-B429
Polished valves - Intake diameter 2.25" & exhaust diameter 1.76"
SVO high performance hydraulic flat tappet camshaft M-625-C460
Valve lift - .588" intake & .614" exhaust
Duration at .050" is 244 degrees intake & 254 exhaust
SVO 460 2-bolt main short block, oil and water pump, oil pan and harmonic balancer
March polished & clear coated under drive pulleys
MSD 6AL ignition and MAS Blaster 2 coil
Taylor Race 10mm spiral core wires
CSI-106 high torque starter
Aeromotive hi-performance electric fuel pump and pressure regulator
