Thread: Coolant leak
Old 01-16-2007, 08:14 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
There are coolant passages on each end of the heads. It could be leaking from one of those where the intake bolts on and be an intake gasket not a head gasket. I second the suggestion regarding a pressure tester, it could helps you trace the problem quicker. If it is either the intake or head gaskets though, you should be able to see traces of the coolant on the area between the mating surfaces.
WDZ
