  #22 (permalink)
Old 01-17-2007, 05:48 AM
jeffko's Avatar
jeffko jeffko is offline
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Ok guys, in simple terms can I use the dot 4 fluid in both brake and clutch after draining present fluid and not worry about residual fluid left behind?
Also, has anyone thought to use a hose shaped insulation as a heat barrier for the hydraulic fluid lines around the headers?
Tis better to burn out than to fade away. So "Lite 'Em Up!"
