Thread: Coolant leak
Old 01-17-2007, 06:28 AM
*13*'s Avatar
*13* *13* is offline
Pressure check it for sure! That'll tell you where the problem is coming from. I had a leak under the valve covers. W/o the pressure tester & would have probably pulled the heads & sent them out to be reworked. Fortunately it was an easy fix, the rocker studs were weaping. Reseal, Retorque, oil change & I was good as new!
ERA FIA 2088
