Old 01-20-2007, 06:36 AM
Ron61's Avatar
Ron61 Ron61 is offline
Go ahead and laugh but, since we don't have many days here that are so cold you need to preheat the oil, I have an old electric blanket that I wrap around the oil pan and up the sides of the motor. Then I just plug it in. I have only used it three times when it was extra cold and I wanted to start the car but it did a fair job, and when it stops working I will pull the heating elements out of it and use it as a mat or floor cover to lay on. I also have one of the outside of the pan heaters that you just stick on the bottom of the pan. I don't glue mine on as I so seldom use it but put it on with a small piece of tape on each corner and that peels right off when I am done.
Edit: Just so you understand, I don't drive my car when it is that cold. But after it sets for a fewweeks I like to start it and run it until the temperatures are up to normal. Anything below 70 degrees is to cold to drive in.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
