Old 01-20-2007, 09:06 PM
NHVANA NHVANA is offline
Cobra Make, Engine: Superformance (SPF2265) 482cu, Tremac TKO 600R
Replace your factory rocker bolts with longer threads. The factory rocker bolt has about 12mm of thread and sooner or later tends to snap the rocker post clean off the SCJ Kaase heads. Also add rocker girdles to tighten everything up.
The single plane inlet manifold will fit under the hood.
Have a balance tube installed between your side pipes, this will resolve the HP drop due to the SPF factory pipes.
Nice colour car!
