Old 01-21-2007, 12:28 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Default Need answers fairly quickly
I have a Contemporary with 351 Cleveland. It has an automatic trans, which I'm replacing. There is a setup available as follows:
Tremec TKO 600, part #TCET5008
McLeod bellhousing to fit Tremec, holds 164 or 157 tooth flywheel. This was on a 351W with dart block.
Spec stage III clutch and pressure plate, 10 1/2 ", fits the above setup
157 tooth billet steel flywheel. Has removable weights of 28 and 50 oz. , can be run as zero weight as well.
Question: will all the above fit my 351 Cleveland in my Contemporary? Any informed answers are greatly appreciated. Thanks!
Doug
