Old 01-22-2007, 05:44 PM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
It's not an E-M, and it's not small block motor, but it is a small block fork with a drivers side pivot, a Willwood slave pulling to the rear, mounted to the frame with a single bolt. The square tube is only a spacer, and the nut holding the bolt is inside the footwell.
From the bottom looking up
