Old 01-22-2007, 08:48 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
Glass beads will dull the finish if its polished. If its raw casting glass beads is the way to go. Clean the intake in safety clean or use brake clean to remove the oil underneath first so the glass will not stick to it. Also, you can blast a spot on the underneath to see if you like the finish first.
