Old 01-23-2007, 02:43 PM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by 55312
I'm just an impartial observer here but I'm dumbfounded by your skepticism on this engine. The Cleveland has a very storied history and is a GREAT engine design. You can get a ton of horsepower out of this motor and have something fairly unique and very servicable. Look into the "Clevor" conversion with the Australian 2v heads or match a cam and intake to the 4v heads. This motor breaths like a true big block and if I were to build another motor, other than an FE, it would be a Cleveland! All those Panteras weren't slugs!
Tim
A Clevor is Cleveland heads on a Windsor block, aka "aftermarket" Boss 302 type motor. IMO, that's the best small block setup, but expensive to build and hard to find intakes anymore.
Doug, don't sweat the 2V heads. You WANT the 2V heads. The 4V heads are too much for a street driven car.
A 351C is basically like a mini-460, with the same canted valve head configuration. They are great motors. The reason they never because as popular as other Ford motors, is because they needed a lot of work to spin them hard, because of their unique main size. That's what made the Boss 302 a killer motor- high winding Windsor short block, with crazy Cleveland heads.
If you want to talk to someone local about Clevelands, talk to Jeff Lawrence (Lawrence Racing Engines). He's a Cleveland nut, and runs low 9s with a Cleveland in a Fox body Mustang in NHRA stock class.
Sal Mennella
