  #28 (permalink)
Old 01-23-2007, 07:19 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by 767Jockey
So if I understand correctly, it's essentially the same as the 4 bolt main block, but with two bolt mains?
Pretty much so, as pointed out they share the same casting numbers on some blocks. Now this is for a standard Cleveland block..there was mention of the XE block which is beefier all around, but regular production ones are even cast for the 4 bolt caps. The difference is, of course, the machining for the extra bolts. Any of the 2 bolt Cleveland blocks I have seen could be converted if someone needed to, in most cases it is unneccesary.
WDZ
