Old 01-24-2007, 10:49 AM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
I am not sure why you need to lower the ride height but here is some information you can use. First there is little or no tension on the torsion bars or coil overs with the suspension is hanging. As for the front height Contemporary suggested you made a jig out of flat stock 18"x1 1/2"x 1/8" with 1/2" holes either 16 3/4" O.C. for a small block or 16 1/4" for a big block, install this where the shock mounts and bolt in the torsion bar bracket that should give you the correct ride height. For sources on Jag xke suspensions you can check www.jcna.com , www.jaguarspecialties.com , www.jag-lovers.org , and www.browneslane.com On these sites there are suspension mods diagrams and other helpful tips also forums that may be helpful. If I remember anything else I will list it. Hope this helps. You should also get in touch with Jeff at jeffg@lentexcorp.com who is organizing a Contemporary owners registry
Cobrarich
