Old 01-26-2007, 08:31 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
We have done it both ways. If you have someone helping and you are using a engine leveler, pull both together. I have extended the arm on my engine lift so I can pull a motor with out getting to close to the front of my Cobra. I do wrap a towel around the lift, just in case it gets to close to the nose of the Cobra. I had to counter balance the engine lift with a 130 lbs of lead. We have used this set up 10 or 12 times with no problems. Slow and easy. We have pull 351w and FE's with TKOs attached. Slow and easy.
Dwight
