Old 01-26-2007, 09:43 PM
ffindling's Avatar
ffindling ffindling is offline
Cobra Make, Engine: Findling 001 - starting scratch build
Red face transmission removal....
Originally Posted by 767Jockey
I dread the huge red oily mess that darn automatic's converter is going to make when I drop it, but that gets cleaned up, my car getting messed up won't. You're 100% correct. I think I got the "so deep in the forest I can't see the trees" syndrome on that one. Thanks.
It shoudn't make a mess provided you unbolt the converter from the flexplate
first. Pull the starter as well. If the converter stays seated in the transmission,
no problem. Some people bolt a strap across the front of the trans made from
some flat steel stock after separating the engine and trans just to make sure
the converter doesn't slip out if the front of the trans gets tilted downwards.
But if you keep the front of the trans supported when you separate it from
the engine, the converter will usually stay put.
...Fred
