Old 01-27-2007, 07:43 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by Shelboss
The 3" tube and the mounting pad look stock, but the straps and bolts outside of them don't. My holes are about 1.25" back from the front of the pad and it is set up for an Fe motor and standard transmission. I am installing a Tremec, which I believe moves the holes back a few inches to where an automatic would mount. I am hoping I just have to drill two new holes. I have also cut the crossmember and installed flanges to make it removable like the newer models. Might be a good time to upgrade!
Where did you get the drawings to modify the crossmember? Did you find it difficult to do? Any info or pictures about the process and result would be appreciated. Thanks.
