Old 01-28-2007, 06:05 PM
Cobrabill's Avatar
Cobrabill Cobrabill is offline
Cobra Make, Engine: Superformance 427 Side-Oiler
Question
Originally Posted by CWizard
MCOULTER - Some things to consider:
1. The braided stainless hose is very abrasive. Do you really want the equivalent of a pack of sandpaper under your dash rubbing around against electrical wires, etc.? You can get high quality AN hoses that are not SS covered, for example, here: http://www.amfmotorsports.com/goodridgeprod.htm
2. Go with AN-3 rather than a larger size. Easier to work with, especially in the tight space behind the dash.
3. One problem I had was getting the right adapter to connect the new hose to the back of the gauge. The Smiths gauge fitting is a British thread, 1/8 inch if memory serves. The amfmotorsports place has those, and will put the fittings on for you. Or, as others have mentioned, there are kits available.
Good luck.
1-i've had braided SS inder my dash on numerous cars for more years than i can remember with no issues.Do a proper install job and forget it.
2-Go as large as reasonable(AN4).Plenty of fittings(90s/45s/etc) available to make installation easy.
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
