Old 01-29-2007, 07:55 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
MCOULTER: Here's what I did to adapt my -4 braided line to the BSP fitting at the Smiths oil-pressure gauge. It took a while, but I found the correct fitting at a real tractor supply store. If the issue that CWizard brought up concerns you, use tie wraps to secure the wires and lines uner the I/P . . . as they should be anyway. Additionally, use a lighter nylon or Kevlar braided line, albeit, not as pretty, but it is just as strong, lighter and is "non-abrasive."
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
