Old 01-30-2007, 04:57 PM
TKing TKing is offline
Cobra Make, Engine: X Everett Morrison, X SPF 140, X SPF1823, currently SPF2778
Hi Greg:
I bought the manual choke for the Demon at Jegs not Summit. I buy parts from both and forget which one. My receipt shows part number 132-421441. I don't know if that number is Demon part number or Jegs. The cost was $36.99. The kit includes almost everything. I had to fadricate 2 small brackets - one to hold cable at the carb and the other for under the dash. You will not need the bracket at the carb if you have vacuum secondaries.
Someone mentioned a sticking choke. The choke linkage extends through the carburator lip which the air cleaner sits on. Kind of odd because there is no way to prevent the linkage from rubbing on the air cleaner. I had to file a notch in the side of my air filter to prevent the linkage from sticking or binding.
Tom
