Old 01-31-2007, 07:23 PM
fasterpatrick's Avatar
fasterpatrick fasterpatrick is offline
Cobra Make, Engine: scratch build self design 4.6l DOHC
well I found a really good deal on ebay for a pedal setup with masters forward mount. with 7/8 masters for the brakes and 3/4 for the clutch. Ya so what. But what I really found bizarre was the info I received from tilton and their form check this out.Patrick,
With your combination, we recommend a 13/16" front and a 1-1/8" rear master.
Regards,
Ehren VanSchmus
Tilton Engineering
ehrenv@tiltonracing.com
Vehicle Info
Make: custom
Model: Cobra replica
Front Brake Information
Number of pistons within each front caliper: 1
Are pistons on one side or both sides of caliper: one
Diameter of pistons on one side of caliper (list all):
Piston 1: 2.38 in
Front rotor diameter: 11 in
Rear Brake Information
Number of pistons within each rear caliper: 1
Piston 1: 1.73 in
Rear rotor diameter: 10.5 in
General Information
What is the motion ratio of your brake pedal (5.5:1, 6.2:1, etc)? 6.25:1
OR
If using a Tilton pedal assembly, please provide part number: -
Vehicle weight (with driver and fuel): 2200 pounds
Vehicle Weight Distribution (with driver and fuel): 55 / 45
Vehicle wheelbase: 90 in.
Front tire diameter (outer): 26 in
Rear tire diameter (outer): 26 in
What is the vehicle being used for (street, road racing, circle track, drag,
etc)?: street/ auto cross
