Old 02-01-2007, 05:56 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Ed: Don't use a high-volume pump unless your engine has extremely high oil clearances, as if it were worn out . Remember that an oil pump always moves the same volume regardless of what it bypasses to maintain the oil pressure set by the pressure regulator. So I suggest you don't install a HV pump and not waste the power as was done "in the old days."
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
