Old 02-01-2007, 05:30 AM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
Originally Posted by Rick Parker
Take note of the base plate design on this pump, it has been available for a few years now and is worth seeking out. It has the shaft supported by the base plate along with the pump body instead of just the pump body as was the only previous option. This design is also available for 289/302. It is a much better design, made by Melling.
http://www.precisionoilpumps.com/ima..._Race_Pump.jpg
I use this pump. Preision oil pumps are blueprinted, and are coated internally to reduce friction. They also feature an adjustable bypass spring so you can set your pressure where ever you want it. Well worth the money. John
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
