Old 02-01-2007, 06:54 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
Are the axle OEM length? Shortened? I used the same IRS (Cougar) in my Slabside chassis i built But i have to shorten the axles 3" i was hoping to find a OEM a little shorter know of any? I also found the disc rear has a larger diameter shaft vs. the drum rear. I tried Taurus RS axle it's a little to short.. I'm trying to avoid making axles i like OEM parts i case i brake one 400 mi. away...
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
