Old 02-01-2007, 11:10 AM
jeffko's Avatar
jeffko jeffko is offline
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Jeff, great comments for a bowtie guy.
I would like to reiterate your comments on oil temps. Engine oil is designed to be fully functional at 212 degrees. It is also the temp that viscosity is determined at. I know of a few guys that run an oil cooler without a stat. Temps for the couple that have oil temp gauges pretty closely follow the water temp or actually a little lower. In affect they are changing the viscosity of their oil and consequently is too think to be 100% effective because the oil is to cold. I don't know much about it, but I have heard about something called bearing wash when using oil that is to thick for the bearing clearances. This is the reason I run mobile one in my other cars. It gets to its viscosity much quicker than standard oil, especially in cold Chicago winters. Even then I still give the car several minutes to warm up the oil. Anyway, the point is that oil temp is critical and you really should have a gauge to monitor it, even with a stat.
I should also clarify that my oil pressures are without an oil cooler which I am presently installing, but my pump was designed for the added restriction. I should loose about 10-15 psi depending on the hose routing. Last year was my first full year of the car being sorted out and the oil temp on hot days was sometimes 250 degrees.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
