Old 02-01-2007, 12:29 PM
CobraV8 CobraV8 is offline
Default guideplates needed for shaft mount rockers?
I want to install a set of shaft mounted rocker arms on Edelbrock Performer RPM heads.
The heads have guideplates installed from the factory. The rockers are positioned on the shafts with bronze washers, however there is still some sideplay left:
Can I remove the guideplates and use non-hardened pushrods or should I keep the guideplates?
Thanks,
Simon
