Thread: Flywheel HELP!!
Old 02-01-2007, 01:45 PM
ponyboyracing ponyboyracing is offline
Registered User
Default Flywheel HELP!!
Hi all, here’s the setup. I have a 1970’s 429 (DOVE-A) that I have built for racing. I have built an engine test stand for it and have it almost ready to go. It will be mated to a C6 transmission when it is in the car but for mounting purposes, while it is on the stand, I have it mated to a late 70’s manual bell housing (D9TA-7505BA). Here is where I am having a problem, I have a 164 tooth flexplate on it for the C6 and apparently it is too small because the starter won’t engage the flexplate. The starter is about a half an inch away from engaging. The research that I have read states that the 1971 429 Mustang/Cougar’s had a Flywheel that measured 15.5 inches, the flex plate I have measures 14.5 inches, I have not been able to find any documentation on the diameter of the Flexplate for a 1971 429/460 mated to a C6. NOW, here is my question…….Does the 429/460 Bell housing require the bigger diameter flywheel? OR is it the same size as the C6 Bell housing? Do I need a different Bell housing? OR do I need the bigger Flywheel?
Final question….what size flywheel / flexplate do I need to get this puppy up and running??
Thanks for the help. Joe
