Old 02-01-2007, 03:12 PM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
Look for a A9L ECU from a 90 & up mustang then you can use MassAir, check F-150 ford truck & Vans for the inline pump there around 190 LPH pumps, any EFI mustang will have
A simple harness it will be a little neater.. Later if you need to make a little more power your set for cam , injectors, and a Tweecer to tune the ECU..
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
