  #22 (permalink)
Old 02-03-2007, 05:36 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
From this discussion on ring types, block material, honing procedures and all the related stuff, it sure looks as though I made a good decision on which book to write. I pretty much cover all that's been discussed here and all other aspects of performance engine building in The Racing Engine Builder's Handbook, plus what type of ring package--tension, material, widths, etc.--to use, affects of the different types of oiling system (wet and dry sump), Nikasil coatings, honing stones, speed, pressure and lubricants, even Total Seal Quick Seat for ring break-in. It goes on and on. The point is you must match every item discussed, even the fuel you're using. But I don't think too many Cobra owners will be using alcohol or propane, but maybe nitrous or blowers.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
