Old 02-03-2007, 02:23 PM
cameron02 cameron02 is offline
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Hi Dan,
Good to hear you are progressing.
Be very carefull and research the advise you are getting.
My engineer told me that we definately do not want the diff and trans outlet to be in a straight line.
If they are in a straight line it can apparently cause the uni joints to lock causing dissaster.
If you are using the Torana diff you will find the center is off to the side anyway so all you have to do is ensure you are also a few degrease higher or lower. Mine trans is higher.
Cameron
