Old 02-04-2007, 07:22 PM
BeasleyRB's Avatar
BeasleyRB BeasleyRB is offline
Cobra Make, Engine: B & B , 351W 400+
Default Clutch Master/Slave bore selection help
Wilwood has a clutch master with 3 available bore diameters (.75, .700, .625) and the "Pull Type" slave is .88 inch. How do you decide which master bore is the best one to use? Smaller the bore, less clutch pedal effort but shorter the stroke on the slave. I don't want to make the mistake of not having enough stroke to release the clutch effectively. Thanks for your help.
Bob
