Old 02-05-2007, 09:43 PM
Rpollard Rpollard is offline
Cobra Make, Engine: Lonestar / 408W Stroker
Default Rebuilt 1964 427 Center oilier, whats it worth?
I have a 1964 427 FE Cross bolt center oiler, that came out of my 1975 boat, this is not a marine engine. The block has been magniflexed, soniced, line bored main caps and bored cylinders .040 over. It has 2 cylinders sleeved and 4 lifter cylinders sleeved. It has a 428 crank, JE pistons, stock FE rods, Comp roller rockers, Comp roller mech lifters, the heads have been ported polished and large valves installed. Edelbrock RPM manifold, 850 CFM Holley, MDS Dist. The motor is at Speed O Motive in West Covina, CA. it will be assembled and dynoed by the end of the month.
This motor belongs in a Cobra, just thought I would post it. I have a 408W in my Cobra that I am very happy with. I could easily buy a Ford 460 Crate motor for the boat. The motor came out of a boat so you will need to change oil pan, water pump.
HMIHNTR
Lone Star LSC427, Speed-o-Motive 408 Stroker
2005 Ford SD 6.0 Harley Davidson /Super Chip 425 HP
1975 24' Campbell V-Drive / 1963 427 Ford
2000 Prowler 32' 5th wheel
And the Harley pulls them both to Lake Havasu
