Old 02-06-2007, 06:42 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Thanks guys. Looks like I'll be pulling the entre front suspension, bead blasting everything, and replacing all the ball joints, rod ends, and bushings. I did get the manual from Jeff, it's a huge help. Have any of you guys put in polyurethane bushings and steering rack mounts? I don't know if I should use rubber or poly. Anyone have any experience with either? Good or bad? Any tricks, difficulties or gotchas on pulling and reassembling the front suspension I should know about? Thanks.
