Old 02-06-2007, 08:30 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by RedBarchetta
0-100 in 6.28. Gotta love those MTs...As much as the other mods helped the performance, I have to think that the drag radials replacing the BFG stones were the largest booster to the improvements. A good and well dialed-in carb is worth 20HP and we all know what the effect on bigger sidepipes can do for these cars. Interesting data, Greg...thanks for posting!
-Dean #747
If anybody in my area with a Superformance original set up 427R wanted to put my Mickey Thompson ET street drag radials on their car for a G-tech pass in the same test area I'd be happy to help. The results would be interesting.
Originally Posted by Slojo
How do those new pipes sound? Any chance of posting a sound bite?
Here's a link to a drag strip pass with sound
drag video with sound
Originally Posted by Madmiles442
Greg,
Great stuff!
Do you have a PN for the S&B cleaner and Cobra oval? How did you get it under the hood, lowered bottom section? I have the K&N oval but it's only 1" or maybe 1 1/2" deep. Based on posts calculating air need, I think I'm fine, but always shopping for more.
I see (in your gallery) you're not using a phenolic spacer under the carb - ever had vapor lock? I have a spacer and I've still had mine choke and gasp from time to time.
Thanks again, this is really helpful info!
The air cleaner is from http://www.cobranda.com/sbovairfielt.html . The intake assembly is the cheaper maid in Taiwan type which actually has a slight drop on the pressed sheet metal base. The top is the usual cast aluminum with the Cobra oval look. I've never had any vapor lock or had a starting problem.
