Originally Posted by Classic Revival
Mike,
This is almost exactly how we decribe it in the wiring instructions. However, you have made one slight error that I feel we should rectify so other do not follow these instructions. DO NOT CUT OFF THE WHITE/RED WIRE.
Under the ADR's the light MUST come on when the system fails & when you turn on the igition. This function is performed by the white/red wire when it is wired into the alternator light circuit.
Your current installation will not pass engineering & will need to be changed.
Ian
I haven't seen anything in any of the manuals I have that describes how to do this. It must be in another manual
I haven't seen.
I've been thinking about the way you suggest wiring it up and can see a bit of a problem. What happens when you get a charge fail problem and the charge light comes on? It seems to me you would get a brake fail warning as well.
I think a better way would be to use a delay circuit much like the seat belt warning light to short the float contacts for 10 seconds when the key is turned on.
