Thread: Oil Temp Sensor
Old 02-09-2007, 12:20 AM
PCC's Avatar
PCC PCC is offline
Fitted my sensor as per Brett's advise using an Earl's Adaptor (good Company to deal with by the way).
I had to replace the Z9 filter with a Z89A one as the Z9 would not fit as per another thread on this subject.
I did read that AU V8's with an Oil Cooler use the shorter filter whereas a Z9 are fitted to the others. Not sure using a shorter filter will make much difference although I have noticed the car is now running with slightly less oil pressure - may be because of the shorter filter.
Curious to know what the oil temp should be for my motor. 5L EFI donk.
Any ideas?
PCC (Peter Craig)
Keep the sun shining
