Old 02-09-2007, 04:06 PM
Bruce Robles Bruce Robles is offline
Cobra Make, Engine: 2004 Kirkham 427 Roadster. New BBM Sideoiler Block, 484 cu. in. built by Valley Head & Racing Engines, Northridge CA. installed 3/20/2016
I forgot,
Forget the Heater you won't need it. When these cars warm up they warm up. The heat transfers thru the body like an Aluminum Frying Pan even in the cool climate of the Pacific Northwest where I live. Not to mention the heat from the side pipes. Remove the Polished Stainless heat shields of the foot wells and put some Kevlar mat between the fiberglass foot box and the Stainless. Also put reflective Kevlar material inside of all the aluminum pieces that make up the transmission tunnel or you'll regret it.
Before you install the engine! Stop and go traffic is why you need it the most.
Bruce
