Old 02-11-2007, 06:14 AM
BlueRooster's Avatar
BlueRooster BlueRooster is offline
Cobra Make, Engine: SPF #623 460/4x2
This has been an issue for me since I swapped the hydraulic throwout for the slave/fork. I have everything adjusted out all the way and I still feel like I need just a bit more. There are adjustments for the linkage itself in the footwell and you should be able to unscrew the rod that goes into the master a bit to give you more throw. I am not familiar with what came with the Lonestar, but you shouldnt have to mess with the master. You should be able to get it dialed in with the linkage and slave.
Dane
