Old 02-11-2007, 12:46 PM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Originally Posted by Dwight
When the slave is mounted to the frame the movement of the motor can change the distance ( adjustment ) of the slave.
The further to the rear of the car the slave is attached to the frame, the less the engine movement will have an effect on the slave. It won't take much distance before the engine movement will be insignificant.
