Old 02-11-2007, 01:19 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Default What grease can I use on plastic?
I have to reassemble my steering column. The main shaft is steel, but it passes through a poly bushing in the top of the outer column. What type of grease can I use to lubricate this point that will stay in the column and lubricate but not damage the plastic top bearing? The bottom "bearing" believe it or not is actually just a heavy piece of dense felt. I guess it doesn't matter what I put on that - grease shouldn't hurt that, right? It's an old MG column, by the way. Thanks.
Doug
