Old 02-11-2007, 06:49 PM
Fastblueoval Fastblueoval is offline
Originally Posted by Excaliber
I for one don't understand the question exactly, NOT that I could do the math if I did!
Wide Ratio: Input 23, Cluster 30, 1st gear 32? Now, how many gears does it take to make 1st gear work? Sounds like THREE? Mine only has two, input and cluster...
I would think it takes all 3 to make up first gear - Input shaft 23T must rotate which in turn rotates the cluster 30T, which in turn would rotate the first gear 32T when first gear is selected - Correct me if I am wrong.
