Thread: T-56 install
Old 02-19-2007, 06:19 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
A T-56 shifter distance from the bellhouseing is the same distance as a T-5
The other thing I learned is the threaded bolt holes on a RAM flywheel are standard AND metric. For their pressure plate the holes line up with the standard holes, not the same bolts that you would get if you asked for a Ford pressure plate to flywheel bolts which are metric. Yeah, sucked learning that one.
