Old 02-20-2007, 08:21 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
I sent you some info on where I would suggest you take her in a PM but you may also do a net search on Historic vehicles in Az. As a 1967 you qualify as a historic but there are a couple of things to qualify like miles driven etc. I do not want to mislead you so do a check but that may exempt you from smog check completely. The check for a 1967 car is just PCV valve and maybe a vac vapor resivour so ? why they are running an idle test at all?
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
