Old 02-20-2007, 12:14 PM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Oh... and clean the fast idle linkage (if any) and the secondary throttle plate. Also check that the 'closer link', for lack of a better word, is bent just right so that is touching the slot and fully closes the secondaries. Sometimes the springs are really like in vacuum secondaries and that combined with a little dirt or interference will hang them a bit. Eleminate a linkage problem by disconnecting it and rev the engine a bit manually and see if it returns to the proper idle. You can also manually 'rev' the secondaries at the same time and note the results.
OhioCobraClub.com
LondonCobraShow.com
