Old 02-20-2007, 02:53 PM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
I am experiencing the very same issue. I set the idle after its warmed up so the problem I have is the idle takes a while to drop down from 1800 to 1100 rpm. Had the MSD checked and confirmed that its hanging up. I have moved to a stronger spring in the curve. THis past weekend I replaced the throttle base plate on the Holley 830 DP with a quick fuel billet base plate. Still need to dial in the carb.
Morgan LeBlanc
Fresno CA
