  #112 (permalink)
Old 02-22-2007, 06:42 AM
quickjack quickjack is offline
The Dart block David posted is generally used in blown alcohol applications making about 3000 HP, so usage wise it is not really a direct comparrison to the Kirkham piece which is not intended to support that kind of abuse.
Cast aluminum has a typical elongation of about 2% before failure, whereas billet has about 10%, so the billet blocks are way stronger than a comparable casting. I think at the intended power levels, the ribs likely are not a big issue.
