Old 02-24-2007, 07:23 AM
Fastblueoval Fastblueoval is offline
Originally Posted by Woodz428
Between the 2 you mentioned, it's easy. The 9" has a removable carrier so gear changes can be done on a bench. The 8.8 has an intregal carrier and the gears come out a cover on the back. There was also an 8" used in many 60's and 70s cars, it looks like a small 9" and has more ribbing (at least the later 8" ones do). Rotating the pinion and counting how may rotations occurs with the axle is the simplest way to check ratio, if it is open(non-posi) one flange will have to be held.
On the 9" unit you will need a wrench to remove the bottom 2 nuts - On a 8" unit they can be removed with a socket - Divide the number of teeth on the ring gear by the number on the pinion will give you the ratio - ex - 39 ring gear and 10 pinion would be 3.90 ratio - Here is a link to a site which may be of some help
http://www.kevinstang.com/Ninecase.htm
Enjoy - Ed
